Le Deal du moment : -29%
499.99 €
 frequences et action entretien durango
flow411
flow411
Masculin Nombre de messages : 59
Véhicule : DODGE DURANGO 5.9L V8 MAGNUM SLT 1998
frequences et action entretien durango Empty
MessageSujet: frequences et action entretien durango   frequences et action entretien durango EmptyMer 6 Nov 2013 - 20:34
salut, voici toute la périodicité de maintenance; certes un peu long mais très pratique
SCHEDULE—A
7,500 Miles (12 000 km) or at 6 months
² Change engine oil.
15,000 Miles (24 000 km) or at 12 months
² Replace engine oil filter.
22,500 Miles (36 000 km) or at 18 months
² Lubricate front suspension ball joints, if
required.
² Inspect front wheel bearings.
² Inspect brake linings.
30,000 Miles (48 000 km) or at 24 months
² Replace engine air cleaner element.
² Replace spark plugs.
37,500 Miles (60 000 km) or at 30 months
² Drain and refill manual transmission fluid (3.9L
only).Drain and refill automatic transmission fluid.
Replace filter and adjust bands.
² Drain and refill transfer case fluid.
45,000 Miles (72 000 km) or at 36 months
required.
² Flush and replace engine coolant at 36 months,
regardless of mileage.
52,500 Miles (84 000 km) or at 42 months
² Flush and replace engine coolant if not done at
36 months.
60,000 Miles (96 000 km) or at 48 months
² Replace ignition cables.
² Inspect PCV valve, replace as necessary.*
67,500 Miles (108 000 km) or at 54 months
required.
75,000 Miles (120 000 km) or at 60 months
only).
² Drain and refill automatic transmission fluid.
² Drain and refill transfer case.
² Flush and replace engine coolant if it has been
30,000 miles (48 000 km) or 24 months since last
change.
82,500 Miles (132 000 km) or at 66 months
change.
90,000 Miles (144 000 km) or at 72 months
required.
97,500 Miles (156 000 km) or at 78 months
105,000 Miles (168 000 km) or at 84 months
change.
112,500 Miles (181 000 km) or at 90 months
only).
required.
change.
120,000 Miles (192 000 km) or at 96 months
*This maintenance is recommended by Chrysler to
the owner but is not required to maintain the warranty
on the PCV valve.
Important: Inspection and service should also be
performed any time a malfunction is observed or suspected.
SCHEDULE—B
3,000 Miles (5 000 km)
² Lubricate steering linkage.
6,000 Miles (10 000 km)
9,000 Miles (14 000 km)
12,000 Miles (19 000 km)
Replace filter and adjust bands.**
required.
² Change rear axle fluid.
² Change front axle fluid.
² Inspect engine air cleaner element, replace
as necessary.
18,000 Miles (29 000 km)
only).
21,000 Miles (34 000 km)
24,000 Miles (38 000 km)
required.
27,000 miles (43 000 km)
33,000 Miles (53,000 km)
36,000 Miles (58 000 km)
required.
only).
39,000 Miles (62 000 km)
42,000 Miles (67 000 km)
² Inspect air cleaner filter, replace as necessary.
48,000 Miles (77 000 km)
required.
51,000 Miles (82 000 km)
36 months.
54,000 Miles (86 000 km)
only).
57,000 Miles (91 000 km)
required.
63,000 Miles (101 000 km)
66,000 Miles (106,000 km)
69,000 Miles (110 000 km)
72,000 Miles (115 000 km)
required.
only).
as necessary.
78,000 Miles (125 000 km)
change.
81,000 Miles (130 000 km)
change.
84,000 Miles (134 000 km)
required.
87,000 Miles (139 000 km)
only).
93,000 Miles (149 000 km)
96,000 Miles (154 000 km)
required.
99,000 Miles (158 000 km)
² Change engine oil
102,000 Miles (163 000 km)
as necessary.
108,000 Miles (173 000 km)
required.
only).
111,000 Miles (178 000 km)
change.
114,000 Miles (182 000 km)
117,000 Miles (187 000 km)
required.
the customer but is not required to maintain warranty
on the PCV valve.
**Prolonged operation with heavy loading, especially
in hot weather, use of vehicle for off-the-highway
operation, trailer towing, and snow plowing
require the more frequent transmission service indicated
with a ** in SCHEDULE—B. Perform these
services if the vehicle is operated under these conditions.
http://go.flow411.voitureh2o.1.1tpe.net
MessageSujet: Re: frequences et action entretien durango   frequences et action entretien durango EmptyMer 6 Nov 2013 - 20:49
Sympa mais c'est tout les 12'000km de toute façon ou une année....
Mais c'est gentil à toi de nous copier-coller le livret d’entretien! lol!
duc.l
duc.l
Véhicule : VW T-Roc 2020
MessageSujet: Re: frequences et action entretien durango   frequences et action entretien durango EmptyVen 5 Déc 2014 - 10:09
Voici le planning d'entretien établi par American Car City... Ils maximisent ! L'argument de "les specs constructeurs sont faites pour les Américains qui ne conduisent pas comme nous" me semble litigieuse... Pour avoir roulé au Canada, très prudemment, je n'ai pas arrêté de me faire doubler...
Qu'en pensez-vous ?
frequences et action entretien durango Plan_d10
MessageSujet: Re: frequences et action entretien durango   frequences et action entretien durango EmptyVen 5 Déc 2014 - 19:06
Pour Dodge Suisse c'est tous les 12'000km... Carnet d’entretien à l'appui.
» Cout entretien Dodge Durango
» Dodge en action... oups!!
» entretien 82 000 kms
» entretien BVA
» Révisions chez DODGE Obligatoire ?
