MODULE, Driver Door (DDM)
B16A0-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW
B16A1-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH
B1852-DRIVER WINDOW SWITCH CIRCUIT STUCK
B1854-DRIVER WINDOW MOTOR CONTROL CIRCUIT LOW
B1855-DRIVER WINDOW MOTOR CONTROL CIRCUIT HIGH
B1858-DRIVER WINDOW POSITION SENSOR POWER SUPPLY LOW
B1859-DRIVER WINDOW POSITION SENSOR POWER SUPPLY HIGH
B185A-DRIVER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE
B1868-DRIVER PASSENGER WINDOW SWITCH CIRCUIT STUCK
B1D04-MIRROR ADJUST SWITCH INPUT CIRCUIT/PERFORMANCE
B1D07-MIRROR ADJUST SWITCH INPUT CIRCUIT STUCK
B1D09-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW
B1D0A-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH
B1D0C-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW
B1D0D-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH
B1D0F-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW
B1D10-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH
B1D1E-DRIVER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE
B1D22-DRIVER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE
B1D4D-MEMORY SWITCH INPUT CIRCUIT STUCK
B210D-BATTERY VOLTAGE LOW
B210E-BATTERY VOLTAGE HIGH
B2218-DOOR MODULE INTERNAL
B2578-DRIVER WINDOW NOT CALIBRATED/LOST CALIBRATION
B2580-DRIVER WINDOW POSITION SENSOR(S) NO SIGNAL
U0019-CAN B BUS
U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM)
U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC)
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0156-LOST COMMUNICATION WITH EOM
U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE
U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE
U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN)
U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE
U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR
U0184-LOST COMMUNICATION WITH RADIO
U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER
U0195-LOST COMMUNICATION WITH SDARS
U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE
U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE
U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE
U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE
U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE
U0212-LOST COMMUNICATION WITH SCM - CAN-B
U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE
U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLIGHT CONTROL MODULE
MODULE, Drivetrain Control (DTCM)
C1078-TIRE REVOLUTIONS RANGE PERFORMANCE
C1456-AWD CLUTCH POWER CONTROL CIRCUIT LOW
C1457-AWD CLUTCH POWER CONTROL CIRCUIT HIGH
C145D-AWD CLUTCH POWER/RETURN CONTROL CIRCUIT OPEN
C1464-FRONT AXLE DISCONNECT CONTROL CIRCUIT LOW
C1465-FRONT AXLE DISCONNECT CONTROL CIRCUIT HIGH
C1477-TRANSFER CASE CLUTCH OVER TEMPERATURE
C147A-TRANSFER CASE TEMPERATURE SENSOR HIGH
C147B-FRONT AXLE DISCONNECT SENSOR CIRCUIT PERFORMANCE
C147C-FRONT AXLE DISCONNECT POWER CIRCUIT LOW
C147D-FRONT AXLE DISCONNECT POWER SUPPLY CIRCUIT HIGH
C2100-BATTERY VOLTAGE LOW
C2101-BATTERY VOLTAGE HIGH
C2112-SENSOR SUPPLY 1 VOLTAGE CIRCUIT HIGH
C2201-INTERNAL CONTROLLER
U0001-CAN C BUS
U0100-LOST COMMUNICATION WITH THE ECM/PCM
U0101-LOST COMMUNICATION WITH TCM
U0121-LOST COMMUNICATION WITH ABS
U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM
U0402-IMPLAUSIBLE DATA RECEIVED FROM TCM
U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS
U0429-IMPLAUSIBLE DATA RECEIVED FROM SCM
U0431-IMPLAUSIBLE DATA RECEIVED FROM FCM/TIPM
MODULE, Electronic Overhead (EOM)
B1A32-UNIVERSAL GARAGE DOOR SWITCH 1 STUCK
B1A33-UNIVERSAL GARAGE DOOR SWITCH 2 STUCK
B1A34-UNIVERSAL GARAGE DOOR SWITCH 3 STUCK
B2217 - EVIC/EOM/CMTC INTERNAL
B222D - ECU UNABLE TO CONFIGURE / CONFIGURATION NOT LEARNED
B2331-VEHICLE NEEDS DEGAUSSED
U0019-CAN B BUS
U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE
MODULE, Electronic Shift (ESM)
P0562-BATTERY VOLTAGE LOW - ESM
P0562-BATTERY VOLTAGE LOW - ESM (COLUMN)
P0563-BATTERY VOLTAGE HIGH - ESM
P0563-BATTERY VOLTAGE HIGH - ESM (COLUMN SHIFT)
P0607-ECU INTERNAL PERFORMANCE - ESM
P0607-ECU INTERNAL PERFORMANCE - ESM (COLUMN SHIFT)
P0930-BTSI CONTROL CIRCUIT LOW
P0930-BTSI CONTROL CIRCUIT LOW - COLUMN SHIFT
P0931-BTSI CONTROL CIRCUIT HIGH
P0931-BTSI CONTROL CIRCUIT HIGH - COLUMN SHIFT
P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE
P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT)
P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE
P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT)
U0002-CAN C BUS OFF PERFORMANCE - ESM
U0002-CAN C BUS OFF PERFORMANCE - ESM (COLUMN SHIFT)
U0100-LOST COMMUNICATION WITH ECM/PCM - ESM
U0100-LOST COMMUNICATION WITH ECM/PCM - ESM (COLUMN SHIFT)
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM (COLUMN SHIFT)
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM (COLUMN SHIFT)
MODULE, Hands Free (HFM)
B143B-MICROPHONE 1 CIRCUIT LOW
B143C-MICROPHONE 1 CIRCUIT HIGH
B143E-MICROPHONE 2 CIRCUIT LOW
B143F-MICROPHONE 2 CIRCUIT HIGH
B2205-ORIGINAL VIN MISSING/MISMATCH
U0019-CAN B BUS
MODULE, Heated Seat (HSM)
B1092-FRONT LEFT SEAT HEATER CONTROL CIRCUIT LOW
B1094-FRONT LEFT SEAT HEATER CONTROL CIRCUIT OPEN
B1096-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT LOW
B1098-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT OPEN
B221A-HEATED SEAT MODULE INTERNAL
U0019-CAN B BUS
U0154-LOST COMMUNICATION WITH OCCUPANT CLASSIFICATION MODULE
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS
IGNITION NODE OR WIN)
U0197-LOST COMMUNICATION WITH HFM
U0212-LOST COMMUNICATION WITH SCCM - CAN B
U0231-LOST COMMUNICATION WITH RAIN SENSING MODULE
MODULE, Intrusion Transceiver (ITM)
B1A37-SECURITY TRANSMITTER SENSOR CIRCUIT LOW
B1A38-SECURITY TRANSMITTER SENSOR CIRCUIT HIGH
B1A3A-SECURITY RECEIVER SENSOR CIRCUIT LOW
B1A3B-SECURITY RECEIVER SENSOR CIRCUIT HIGH
B1A3C-INTERNAL SIREN BATTERY
B1A3D-SIREN BATTERY TAMPER / LOSS OF POWER SUPPLY
B1A3E-SIREN / ITM MISMATCH
B1A3F-ITM ARMING SEQUENCE PERFORMANCE
B1A41-SECURITY TRANSMITTER SENSOR CIRCUIT OPEN
B1A42-SECURITY TRANSMITTER SENSOR CIRCUIT SHORTED TOGETHER
B1A43-SECURITY TRANSMITTER SENSOR RETURN CIRCUIT LOW
B1A44-SECURITY RECEIVER SENSOR CIRCUIT OPEN
B1A45-SECURITY RECEIVER SENSOR CIRCUIT SHORTED TOGETHER
B1A46-SECURITY RECEIVER SENSOR RETURN CIRCUIT LOW
B1A47-SECURITY TRANSMITTER/RECEIVER SENSOR RETURN CIRCUIT HIGH
B2206-CURRENT VIN MISSING/MISMATCH
B222A-VEHICLE LINE MISMATCH
B223C-INTRUSION TRANSCEIVER MODULE INTERNAL
U0019-CAN B BUS
U0100-LOST COMMUNICATION WITH ENGINE CONTROL MODULE/POWERTRAIN CONTROL
MODULE
U0121-LOST COMMUNICATION WITH ANTI—LOCK BRAKE MODULE
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE (TIPM)
U110D-LOST COMMUNICATION WITH SECURITY SIREN
U1416-IMPLAUSIBLE SECURITY SIREN SIGNAL RECEIVED
MODULE, Light Rain Sensor (LRSM)
B2211-RAIN SENSOR MODULE INITIALIZATION PERFORMANCE
B221D-(RSM) RAIN SENSOR MODULE INTERNAL
B2329-RAIN SENSOR OPTICAL PATH 1 PERFORMANCE
B232A-RAIN SENSOR OPTICAL PATH 2 PERFORMANCE
B232B-RAIN SENSOR OPTICAL PATH 3 PERFORMANCE
B232C-RAIN SENSOR OPTICAL PATH 4 PERFORMANCE
U0019-CAN B BUS
MODULE, Memory Seat (MSMD)
B1D56-ADJUSTABLE PEDAL SENSOR CIRCUIT LOW
B1D57-ADJUSTABLE PEDAL SENSOR CIRCUIT HIGH
B1D5B-ADJUSTABLE PEDAL SWITCH CIRCUIT PERFORMANCE
B1D5C-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK FORWARD
B1D5D-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK REARWARD
B1D62-POWER SEAT SWITCH STUCK
B1D63-POWER SEAT SWITCH OPEN
B1D67-ADJUSTABLE PEDAL CONTROL CIRCUIT PERFORMANCE
B1D6D-SEAT HORIZONTAL POSITION SENSOR CIRCUIT LOW
B1D6E-SEAT HORIZONTAL POSITION SENSOR CIRCUIT HIGH
B1D71-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT LOW
B1D72-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT HIGH
B1D75-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT LOW
B1D76-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT HIGH
B1D79-SEAT RECLINER POSITION SENSOR CIRCUIT LOW
B1D7A-SEAT RECLINER POSITION SENSOR CIRCUIT HIGH
B1D7B-SEAT HORIZONTAL MOTOR CONTROL CIRCUIT PERFORMANCE
B1D7F-SEAT FRONT VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE
B1D83-SEAT REAR VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE
B1D87-SEAT BACKREST MOTOR CONTROL CIRCUIT PERFORMANCE
B1D8D-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT LOW
B1D8E-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT HIGH
B1D91-STEERING COLUMN TILT POSITION SENSOR CIRCUIT LOW
B1D92-STEERING COLUMN TILT POSITION SENSOR CIRCUIT HIGH
B1D93-STEERING COLUMN TELESCOPE MOTOR CONTROL CIRCUIT PERFORMANCE
B1D97-STEERING COLUMN TILT MOTOR CONTROL CIRCUIT PERFORMANCE
B1D9B-SEAT HORIZONTAL FRONT STOP NOT LEARNED
B221C-MEMORY SEAT MODULE INTERNAL
U0019-CAN B BUS
U0020-CAN B BUS OFF PERFORMANCE
MODULE, Park Assist (PTS)
B128E-11-PTS SENSOR 1-CIRCUIT SHORT TO GROUND
B128E-12-PTS SENSOR 1-CIRCUIT SHORT TO BATTERY
B128E-25-PTS SENSOR 1-SIGNAL SHAPE / WAVEFORM FAILURE
B128E-92-PTS SENSOR 1-PERFORMANCE OR INCORRECT OPERATION
B128F-11-PTS SENSOR 2-CIRCUIT SHORT TO GROUND
B128F-12-PTS SENSOR 2-CIRCUIT SHORT TO BATTERY
B128F-25-PTS SENSOR 2-SIGNAL SHAPE / WAVEFORM FAILURE
B128F-92-PTS SENSOR 2-PERFORMANCE OR INCORRECT OPERATION
B1290-11-PTS SENSOR 3-CIRCUIT SHORT TO GROUND
B1290-12-PTS SENSOR 3-CIRCUIT SHORT TO BATTERY
B1290-25-PTS SENSOR 3-SIGNAL SHAPE / WAVEFORM FAILURE
B1290-92-PTS SENSOR 3-PERFORMANCE OR INCORRECT OPERATION
B1291-11-PTS SENSOR 4-CIRCUIT SHORT TO GROUND
B1291-12-PTS SENSOR 4-CIRCUIT SHORT TO BATTERY
B1291-25-PTS SENSOR 4-SIGNAL SHAPE / WAVEFORM FAILURE
B1291-92-PTS SENSOR 4-PERFORMANCE OR INCORRECT OPERATION
B1292-11-PTS SENSOR 5-CIRCUIT SHORT TO GROUND
B1292-12-PTS SENSOR 5-CIRCUIT SHORT TO BATTERY
B1292-25-PTS SENSOR 5-SIGNAL SHAPE / WAVEFORM FAILURE
B1295-92-PTS SENSOR 5-PERFORMANCE OR INCORRECT OPERATION
B1293-11-PTS SENSOR 6-CIRCUIT SHORT TO GROUND
B1293-12-PTS SENSOR 6-CIRCUIT SHORT TO BATTERY
B1293-25-PTS SENSOR 6-SIGNAL SHAPE / WAVEFORM FAILURE
B1293-92-PTS SENSOR 6-PERFORMANCE OR INCORRECT OPERATION
B1295-11-PTS SENSOR 8 CIRCUIT SHORT TO GROUND
B1295-12-PTS SENSOR 8-CIRCUIT SHORT TO BATTERY
B1295-25-PTS SENSOR 8-SIGNAL SHAPE / WAVEFORM FAILURE
B1295-92-PTS SENSOR 8-PERFORMANCE OR INCORRECT OPERATION
B1296-11-PTS SENSOR 9-CIRCUIT SHORT TO GROUND
B1296-12-PTS SENSOR 9-CIRCUIT SHORT TO BATTERY
B1296-25-PTS SENSOR 9-SIGNAL SHAPE / WAVEFORM FAILURE
B1296-92-PTS SENSOR 9-PERFORMANCE OR INCORRECT OPERATION
B1297-11-PTS SENSOR 10-CIRCUIT SHORT TO GROUND
B1297-12-PTS SENSOR 10-CIRCUIT SHORT TO BATTERY
B1297-25-PTS SENSOR 10-SIGNAL SHAPE / WAVEFORM FAILURE
B1297-92-PTS SENSOR 10-PERFORMANCE OR INCORRECT OPERATION
B1298-11-PTS SENSOR 11-CIRCUIT SHORT TO GROUND
B1298-12-PTS SENSOR 11-CIRCUIT SHORT TO BATTERY
B1298-25-PTS SENSOR 11-SIGNAL SHAPE / WAVEFORM FAILURE
B1298-92-PTS SENSOR 11-PERFORMANCE OR INCORRECT OPERATION
B210C-16-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE BELOW THRESHOLD
B210C-17-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE ABOVE THRESHOLD
B2128-16-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
B2128-17-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD
B2129-16-PTS DISPLAY SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
B21DD-16-SYSTEM VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
B21DD-17-SYSTEM VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD
B222A-00-VEHICLE LINE MISMATCH
B2232-00-(PTS) PARKTRONICS INTERNAL
B2233-00-(PTS) PARKTRONICS FRONT DISPLAY INTERNAL
B2234-00-(PTS) PARKTRONICS REAR DISPLAY INTERNAL
U0010-00-CAN INTERIOR BUS
U0141-00-LOST COMMUNICATION WITH IPM (FCM/TIPM)
U0155-00-LOST COMMUNICATION WITH CLUSTER/CCN
U0423-00-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN
U0431-00-IMPLAUSIBLE DATA RECEIVED FROM IPM (FCM/TIPM)
U1101-00-LOST COMMUNICATION WITH PTS DISPLAY-REAR 1
U112B-00-LOST COMMUNICATION WITH PTS DISPLAY-FRONT 1
MODULE, Passenger Door (PDM)
B16A4-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW
B16A5-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH
B185D-PASSENGER WINDOW SWITCH CIRCUIT STUCK
B185F-PASSENGER WINDOW MOTOR CONTROL CIRCUIT LOW
B1860-PASSENGER WINDOW MOTOR CONTROL CIRCUIT HIGH
B1863-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY LOW
B1864-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY HIGH
B1865-PASSENGER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE
B1D12-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW
B1D13-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH
B1D15-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW
B1D16-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH
B1D18-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW
B1D19-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH
B1D2A-PASSENGER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE
B1D2E-PASSENGER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE
B2219-PASSENGER DOOR MODULE INTERNAL
B2577-PASSENGER WINDOW NOT CALIBRATED/LOST CALIBRATION
B2581-PASSENGER WINDOW POSITION SENSOR(S) NO SIGNAL
U0019-CAN B BUS
MODULE, Passive Entry (PEM)
B1A71-01-PASSIVE ENTRY ANTENNA 1 - GENERAL ELECTRICAL FAILURE
B1A72-01-PASSIVE ENTRY ANTENNA 2 - GENERAL ELECTRICAL FAILURE
B1A73-01-PASSIVE ENTRY ANTENNA 3 - GENERAL ELECTRICAL FAILURE
B1A74-01-PASSIVE ENTRY ANTENNA 4 - GENERAL ELECTRICAL FAILURE
B2199-16-BATTERY VOLTAGE - CIRCUIT VOLTAGE BELOW THRESHOLD
B2199-17-BATTERY VOLTAGE - CIRCUIT VOLTAGE ABOVE THRESHOLD
B21DD-84-SYSTEM VOLTAGE - SIGNAL BELOW ALLOWABLE RANGE
B219DD-85-SYSTEM VOLTAGE - SIGNAL ABOVE ALLOWABLE RANGE
B2205-00-ORIGINAL VIN MISSING/MISMATCH
B223B-00-VEHICLE CONFIGURATION MISMATCH
B229B-00-PASSIVE ENTRY MODULE (PEM) INTERNAL
B259A-00-FRONT LEFT DOOR HANDLE SENSE
B259B-00-FRONT RIGHT DOOR HANDLE SENSE
B259E-00-TRUNK/LIFTGATE DOOR HANDLE SENSE
B25A3-00-FRONT LEFT DOOR HANDLE SENSOR
B25A4-00-FRONT RIGHT DOOR HANDLE SENSOR
U0019-00-CAN B BUS
U0020-00-CAN B BUS OFF PERFORMANCE
U0021-00-CAN B BUS (+) CIRCUIT OPEN
U0022-00-CAN B BUS (+) CIRCUIT LOW
U0023-00-CAN B BUS (+) CIRCUIT HIGH
U0024-00-CAN B BUS (-) CIRCUIT OPEN
U0025-00-CAN B BUS (-) CIRCUIT LOW
U0026-00-CAN B BUS (-) CIRCUIT HIGH
MODULE, Police/Taxi Interface (PTIM)
P1462-FUEL LEVEL OUTPUT CIRCUIT LOW
P1463-FUEL LEVEL OUTPUT CIRCUIT HIGH
P1504-VEHICLE SPEED OUTPUT CIRCUIT LOW
P1505-VEHICLE SPEED OUTPUT CIRCUIT HIGH
P164A-MIL OUTPUT CIRCUIT LOW
P164B-MIL OUTPUT CIRCUIT HIGH
P170A-PARK/NEUTRAL OUTPUT CIRCUIT LOW
P170B-PARK/NEUTRAL OUTPUT CIRCUIT HIGH
P170C-ENGINE RPM OUTPUT CIRCUIT LOW
P170D-ENGINE RPM OUTPUT CIRCUIT HIGH
C1088-BRAKE LAMP SWITCH OUTPUT CIRCUIT LOW
C1089-BRAKE LAMP OUTPUT CIRCUIT HIGH
B1693-ACCESSORY DIMMING CONTROL CIRCUIT LOW
B1694-ACCESSORY DIMMING CONTROL CIRCUIT HIGH
B17CF-EMERGENCY FLASHING LAMP REQUEST 1 CIRCUIT HIGH
B17D2-EMERGENCY FLASHING LAMP REQUEST 2 CIRCUIT HIGH
B17D4-HEADLAMP STATUS OUTPUT CIRCUIT LOW
B17D5-HEADLAMP STATUS OUTPUT CIRCUIT HIGH
B19B4-DRIVER DOOR AJAR OUTPUT CIRCUIT LOW
B19B5-DRIVER DOOR AJAR OUTPUT CIRCUIT HIGH
B1A5B-PANIC ALARM MUTE REQUEST CIRCUIT HIGH
B1A5D-PANIC ALARM ACTIVATION OUTPUT CIRCUIT LOW
B1A5E-PANIC ALARM ACTIVATION STATUS CIRCUIT HIGH
B1CC1-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT LOW
B1CC2-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT HIGH
B237C-DATA COMMUNICATION RADIO INPUT CIRCUIT HIGH
B237F-HORN MUTE REQUEST CIRCUIT HIGH
B2381-DRIVER SEAT BELT OUTPUT CIRCUIT LOW
B2382-DRIVER SEAT BELT OUTPUT CIRCUIT HIGH
B2384-HORN SWITCH OUTPUT CIRCUIT LOW
B2385-HORN SWITCH OUTPUT CIRCUIT HIGH
B2720-FRONTAL IMPACT OUTPUT CIRCUIT LOW
B271F-FRONTAL IMPACT OUTPUT CIRCUIT HIGH
U0021-CAN B BUS (+) CIRCUIT OPEN
U0022-CAN B BUS (+) CIRCUIT LOW
U0023-CAN B BUS (+) CIRCUIT HIGH
U0024-CAN B BUS (-) CIRCUIT OPEN
U0025-CAN B BUS (-) CIRCUIT LOW
U0026-CAN B BUS (-) CIRCUIT HIGH
U0156-LOST COMMUNICATION WITH ELECTRONIC OVERHEAD MODULE
U0159-LOST COMMUNICATION WITH PARK ASSIST CONTROL MODULE
U0212-LOST COMMUNICATION WITH STEERING COLUMN CONTROL MODULE
MODULE, Powertrain Control (PCM), NGC
P000B-BANK 1 CAMSHAFT 2 POSITION SLOW RESPONSE
P0013-BANK 1 CAMSHAFT 2 POSITION ACTUATOR CIRCUIT OPEN
P0014-EXHAUST TARGET ERROR BANK 1
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 2.7L
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 3.5L
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 5.7L/SRT8
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW
P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
P0057-O2 SENSOR 2/2 HEATER CIRCUIT LOW
P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH
P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE
P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
P0107-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW
P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR 1 PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT LOW
P0113-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH
P0116-ENGINE COOLANT TEMPERATURE SENSOR PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 2.7L
P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 3.5L/5.7L/SRT8
P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 2.7L
P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 3.5L/5.7L/SRT8
P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE
P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW
P0131-O2 SENSOR 1/1 CIRCUIT LOW
P0132-O2 SENSOR 1/1 CIRCUIT HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0137-O2 SENSOR 1/2 CIRCUIT LOW
P0138-O2 SENSOR 1/2 CIRCUIT HIGH
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P013A-O2 SENSOR 1/2 SLOW RESPONSE - RICH TO LEAN
P013C-O2 SENSOR 2/2 SLOW RESPONSE - RICH TO LEAN
P0140-O2 SENSOR 1/2 NO ACTIVITY DETECTED
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0151-O2 SENSOR 2/1 CIRCUIT LOW
P0152-O2 SENSOR 2/1 CIRCUIT HIGH
P0153-O2 SENSOR 2/1 SLOW RESPONSE
P0155-O2 SENSOR 2/1 HEATER PERFORMANCE
P0157-O2 SENSOR 2/2 CIRCUIT LOW
P0158-O2 SENSOR 2/2 CIRCUIT HIGH
P0159-O2 SENSOR 2/2 SLOW RESPONSE
P0160-O2 SENSOR 2/2 NO ACTIVITY DETECTED
P0161-O2 SENSOR 2/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0174-FUEL SYSTEM 2/1 LEAN
P0175-FUEL SYSTEM 2/1 RICH
P0196-ENGINE OIL TEMPERATURE SENSOR PERFORMANCE
P0197-ENGINE OIL TEMPERATURE SENSOR CIRCUIT LOW
P0198-ENGINE OIL TEMPERATURE SENSOR CIRCUIT HIGH
P0201-FUEL INJECTOR 1 CIRCUIT/OPEN
P0202-FUEL INJECTOR 2 CIRCUIT/OPEN
P0203-FUEL INJECTOR 3 CIRCUIT/OPEN
P0204-FUEL INJECTOR 4 CIRCUIT/OPEN
P0205-FUEL INJECTOR 5 CIRCUIT/OPEN
P0206-FUEL INJECTOR 6 CIRCUIT/OPEN
P0207-FUEL INJECTOR 7 CIRCUIT/OPEN
P0208-FUEL INJECTOR 8 CIRCUIT/OPEN
P0221-THROTTLE POSITION SENSOR 2 CIRCUIT PERFORMANCE
P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW
P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH
P0298-ENGINE OIL TEMPERATURE TOO HIGH
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER 1 MISFIRE
P0302-CYLINDER 2 MISFIRE
P0303-CYLINDER 3 MISFIRE
P0304-CYLINDER 4 MISFIRE
P0305-CYLINDER 5 MISFIRE
P0306-CYLINDER 6 MISFIRE
P0307-CYLINDER 7 MISFIRE
P0308-CYLINDER 8 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR 1 CIRCUIT
P0330-KNOCK SENSOR 2 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 2.7
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 3.5L
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 5.7L/SRT8
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 2.7L
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 3.5L
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 5.7L/SRT8
P0401-EGR SYSTEM PERFORMANCE
P0403-EGR CONTROL CIRCUIT/OPEN
P0404-EGR POSITION SENSOR PERFORMANCE
P0405-EGR POSITION SENSOR CIRCUIT LOW
P0406-EGR POSITION SENSOR CIRCUIT HIGH
P0420-CATALYST EFFICIENCY (BANK 1)
P0430-CATALYST EFFICIENCY (BANK 2)
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0443-EVAP PURGE CONTROL CIRCUIT
P0452-EVAP PRESSURE SWITCH STUCK CLOSED
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0457-LOOSE FUEL CAP
P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT
P050B-COLD START IGNITION TIMING PERFORMANCE
P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Equipped with ABS)
P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Not Equipped with ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Equipped with ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Not Equipped with ABS)
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED
P050D-COLD START ROUGH IDLE
P0513-INVALID SKIM KEY
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
P0522-ENGINE OIL PRESSURE SENSOR CIRCUIT LOW
P0522-OIL PRESSURE TOO LOW - 3.5L
P0523-ENGINE OIL PRESSURE SENSOR CIRCUIT HIGH
P0524-ENGINE OIL PRESSURE TOO LOW
P0551-POWER STEERING PRESSURE SWITCH PERFORMANCE
P0571-BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 STUCK ON
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (EXCEPT POLICE PACKAGE)
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (POLICE PACKAGE)
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (EXCEPT POLICE PACKAGE)
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (POLICE PACKAGE)
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (EXCEPT POLICE PACKAGE)
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (POLICE PACKAGE)
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (EXCEPT POLICE PACKAGE)
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (POLICE PACKAGE)
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (EXCEPT POLICE PACKAGE)
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (POLICE PACKAGE)
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0606-INTERNAL CONTROL PROCESSOR
P060B-ETC A/D GROUND PERFORMANCE
P060D-ETC LEVEL 2 APP PERFORMANCE
P060E-ETC LEVEL 2 TPS PERFORMANCE
P060F-ETC LEVEL 2 ECT PERFORMANCE
P061A-ETC LEVEL 2 TORQUE PERFORMANCE
P061C-ETC LEVEL 2 RPM PERFORMANCE
P0622-GENERATOR FIELD CONTROL CIRCUIT/OPEN
P0627-FUEL PUMP CONTROL CIRCUIT/OPEN
P062C-ETC LEVEL 2 MPH PERFORMANCE
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM SECRET KEY NOT STORED IN PCM
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0645-A/C CONTROL CIRCUIT/OPEN
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0660-MANIFOLD TUNING VALVE (MTV) CONTROL CIRCUIT
P0685-AUTO SHUTDOWN CONTROL CIRCUIT
P0688-ASD/MAIN SENSE CIRCUIT
P0573-BRAKE SWITCH 1 STUCK OFF
P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
P0703-BRAKE SWITCH 2 PERFORMANCE
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE
P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
P1115-GENERAL TEMPERATURE RATIONALITY
P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
P1239-ENGINE OIL TEMPERATURE TOO LOW
P1404-EGR CLOSE POSITION PERFORMANCE
P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE
P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE
P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE
P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE
P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (Equipped with ABS)
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (Equipped with
ABS)
P150D-COLD START ROUGH IDLE - OPEN THROTTLE START
P1521-INCORRECT ENGINE OIL TYPE
P1524- OIL PRESSURE OUT OF RANGE - CAMSHAFT ADVANCE/RETARD DISABLED
P1572-BRAKE PEDAL STUCK ON
P1573-BRAKE PEDAL STUCK OFF
P1593-SPEED CONTROL SWITCH 1/2 STUCK (EXCEPT POLICE PACKAGE)
P1593-SPEED CONTROL SWITCH 1/2 STUCK (POLICE PACKAGE)
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION FAILURE
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1618-SENSOR REFERENCE VOLTAGE 1 ERRATIC
P1628-SENSOR REFERENCE VOLTAGE 2 ERRATIC
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1897-LVL2 RPM FAIL - NO POST
P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT
P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW
P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH
P2066-FUEL LEVEL SENSOR 2 PERFORMANCE
P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW
P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH
P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
P2077-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT LOW
P2078-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT HIGH
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT/OPEN - BANK 1
P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE - BANK 1
P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
P2108-ELECTRONIC THROTTLE CONTROL MODULE PERFORMANCE
P2110-ELECTRONIC THROTTLE CONTROL SYSTEM - FORCED LIMITED RPM
P2111-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO CLOSE
P2112-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO OPEN
P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE
P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
P2161-VEHICLE SPEED SENSOR 2 ERRATIC (with ABS)
P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
P2172-HIGH AIRFLOW/VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION)
P2174-LOW AIRFLOW/RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
P2175-LOW AIRFLOW/RESTRICTION DETECTED (SLOW ACCUMULATION)
P2181-COOLING SYSTEM PERFORMANCE
P2271-O2 SENSOR 1/2 SIGNAL BIASED RICH
P2273-O2 SENSOR 2/2 SIGNAL BIASED RICH
P2299-BRAKE PEDAL POSITION/ACCELERATOR PEDAL POSITION INCOMPATIBLE
P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2320-IGNITION COIL 7 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2323-IGNITION COIL 8 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
P2503-CHARGING SYSTEM OUTPUT LOW
P2504-CHARGING SYSTEM OUTPUT HIGH
P2533-IGNITION SWITCH RUN/START POSITION CIRCUIT
P2610-PCM INTERNAL ENGINE OFF TIMER PERFORMANCE
P3400-MDS RATIONALITY BANK 1
P3401-MDS SOLENOID 1 CIRCUIT
P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE
P3425-MDS SOLENOID 4 CIRCUIT
P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE
P3441-MDS SOLENOID 6 CIRCUIT
P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE
P3449-MDS SOLENOID 7 CIRCUIT
P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE
P3497-MDS RATIONALITY BANK 2
U0001-CAN C BUS
U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE
U0104-LOST COMMUNICATION WITH ACC MODULE
U0141-LOST COMMUNICATION WITH FCM/TIPM
U110A-LOST COMMUNICATION WITH SCM (SAS)
U110C-LOST FUEL LEVEL MESSAGE
U110E-LOST AMBIENT TEMPERATURE MESSAGE
U110F-LOST FUEL VOLUME MESSAGE
U1110-LOST VEHICLE SPEED MESSAGE
U1113-LOST A/C PRESSURE MESSAGE
U1120-LOST WHEEL DISTANCE MESSAGE
U1186-LOST COMMUNICATION WITH CRUISE CONTROL MODULE
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
U1431-IMPLAUSIBLE CCM DATA RECEIVED
MODULE, Steering Control (SCM)
B1489-STEERING WHEEL CONTROL AUDIO SWITCH CIRCUIT
B148A-STEERING WHEEL CONTROL MENU SWITCH CIRCUIT
B148B-STEERING WHEEL CONTROL UP SWITCH CIRCUIT
B148C-STEERING WHEEL CONTROL DOWN SWITCH CIRCUIT
B148D-STEERING WHEEL CONTROL SIDE SWITCH CIRCUIT
B148E-STEERING WHEEL CONTROL [+] SWITCH CIRCUIT
B148F-STEERING WHEEL CONTROL [-] SWITCH CIRCUIT
B1490-STEERING WHEEL CONTROL C/T SWITCH CIRCUIT
B1DA0-STEERING COLUMN TILT SWITCH CIRCUIT STUCK
B1DA5-STEERING COLUMN TELESCOPE SWITCH CIRCUIT STUCK
B2225-STEERING CONTROL MODULE INTERNAL
B2332-HORN SWITCH INPUT CIRCUIT/PERFORMANCE
C1219-STEERING ANGLE SENSOR ERRATIC PERFORMANCE
P0585-SPEED CONTROL MULTIPLEXED SWITCH 1/2 CORRELATION
U0019-CAN B BUS CIRCUIT
U0155-LOST COMMUNICATION WITH CLUSTER / CCN
U1109-LOST COMMUNICATION WITH LIN STEERING WHEEL CONTROLS
MODULE, Sunroof (SUNR)
B1841-SUNROOF OPEN SWITCH INPUT CIRCUIT HIGH
B1844-SUNROOF CLOSE SWITCH INPUT CIRCUIT HIGH
B1847-SUNROOF VENT SWITCH INPUT CIRCUIT HIGH
B1849-SUNROOF MOTOR CONTROL CIRCUIT/PERFORMANCE (STALLED)
B210A-SYSTEM VOLTAGE LOW
B210B-SYSTEM VOLTAGE HIGH
B2227-SUNROOF ECU INTERNAL
U0019-CAN B BUS
