Display Star Wars Unlimited Ombres de la Galaxie : ...
 Transmission range sensor
BigHorn
Masculin Nombre de messages : 565
Transmission range sensor Empty
MessageSujet: Transmission range sensor   Transmission range sensor EmptyDim 24 Jan 2016 - 9:17
Hello,
Le garage me dit de remplacer le transmission range sensor. Capteur de position en neutre ou parking.
Je ne trouve pas d'équivalent sur rockauto mis à part le overdrive solenoid ou governor solenoid
Dans ma doc je trouve pourtant le transmission range sensor
Quelqu'un a une idée?
BigHorn
MessageSujet: Re: Transmission range sensor   Transmission range sensor EmptyDim 24 Jan 2016 - 9:21
TRANSMISSION RANGE SENSOR
DESCRIPTION
The Transmission Range Sensor (TRS) (Fig. 258) has 3 primary functions:
• Provide a PARK/NEUTRAL start signal to the engine controller and the starter relay.
• Turn the Back-up lamps on when the transmis- sion is in REVERSE and the engine (ignition) is on. • Provide a transmission range signal to the
instrument cluster.
Fig. 258 Transmission Range Sensor
The sensor is mounted in the transmission housing near the valve body, just above the pan rail. It’s in the same position as the Park/Neutral switch on other transmissions. The TRS contacts a cammed surface on the manual valve lever. The cammed surface translates the rotational motion of the manual lever into the linear motion of the sensor. The cammed surface on the man- ual lever is comprised of two parts controlling the TRS signal: The insulator portion contacts the switch poppet when the manual lever is not in PARK or NEUTRAL. The manual lever itself contacts the poppet when the lever is in PARK or NEUTRAL; providing a ground for the signal from the starter relay and the JTEC engine controller.
BigHorn
MessageSujet: Re: Transmission range sensor   Transmission range sensor EmptyDim 24 Jan 2016 - 11:28
Voila enfin trouvé sur rockauto, neutral safety switch/range sensor. Catégorie electrical switch and relay.
Le problème est que sur rockauto cette pièce correspond à la boite 48RE, et je dispose de la boite 452RFE. Celle-ci n'est apparemment pas compatible.
BigHorn
MessageSujet: Re: Transmission range sensor   Transmission range sensor EmptyDim 24 Jan 2016 - 12:48
Voila, mais je ne trouve cette pièce nulle part
https://youtu.be/icGA1kJ7fIs
MessageSujet: Re: Transmission range sensor   Transmission range sensor EmptyDim 24 Jan 2016 - 22:56
Prend le sensor chez le concessionnaire à ce moment là, comme ça tu est sur
» p0071 ambiant air température sensor range performance
» Mes Range
» co 2 sensor
» Sensor a temperature !!!!
» infornmation sur oxigene sensor
